Should I Seal My Basement Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 08:39 PM   #1
Rewards Points: 160
Should I seal my basement floor?
Im a new home owner and I figure since I haven't moved in yet now would be the time to seal the basement floor. The basement has flooded once before but the crack that caused it to leak has been repaired with epoxy. What do you guys suggest I do? I eventually plan on finishing half of the basement but that is a long ways down the road.
word2yamutha is offline   Reply With Quote
Old 03-18-2013, 08:47 PM   #2
Rewards Points: 14,306
Sealing will do no good.
90% of the water proofing and prevention is done outside to prevent the water from getting there in the first place.
Grade running away from the foundtion, working gutters, drain tiles.
There also should be a sump pump in the basement.
sam floor (03-20-2013)
Old 03-18-2013, 09:03 PM   #3
Rewards Points: 160
Yes we do have a sump pump. I have a small leak on one side of the basement wall. It doesn't leak when its raining outside, but I though it might have something to do with ground thawing out?
Old 03-19-2013, 09:03 AM   #4
Rewards Points: 264
I am no expert on this by any means and I do agree with the previous poster, that most of this is caused from other things. However, I would think it would not hurt to do this and it could help. So why not do it.
Awoodfloorguy is offline   Reply With Quote
Old 03-20-2013, 01:18 PM   #5
similar to wood2; I"m also a new homeowner with a basement ....(in CA) and I'd like to finish the concrete floor as inexpensively as possible. Considering a concrete Etching Stain such as Quikrete with a high gloss sealer. My quickie budget for the 1,000 sq ft basement is about $800 or about 80 cents / sq ft. My questions:
1 - Do i need to sand / prep the concrete prior to staining for a smoother final finish?
2 - Is there a another flooring material that would cost less?
3 - Any other flooring recommendations / comments / suggestions?
kirkb is offline   Reply With Quote
Old 03-20-2013, 04:25 PM   #6
Rewards Points: 3,824
If you seal that floor,you will not be able to stain or tile it down the road,unless you compleatly remove the sealer,and that would require grinding the surface.
Canarywood1 is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Basement Floor drainage help wizardofgore Building & Construction 3 07-11-2011 10:42 AM
Water Seal basement floor or not? hellothere123 General DIY Discussions 1 06-30-2011 06:51 AM
To seal basement floor or not to seal? hellothere123 General DIY Discussions 3 06-16-2011 04:12 PM
Wet basement floor Saiboogu Building & Construction 9 08-12-2009 05:19 PM
