Should I Replace This Subfloor? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 05:34 PM   #1
should I replace this subfloor?
Hi all,
We took out the vinyl flooring toilet in a rarely used bathroom in order to do some tiling, and found some very water-stained subfloor. It didn't feel wet or any different really from the rest of the subfloor. Do we need to replace this section of subfloor? What do you think?
Thanks a lot.
bublsort is offline   Reply With Quote
Old 01-21-2012, 05:35 PM   #2
Vinyl flooring AND toilet, sorry.
Old 01-21-2012, 05:43 PM   #3
mike owes me $53 dollars
Tech Dawg's Avatar
Is that the subfloor or luan underlayment?
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 01-21-2012, 05:46 PM   #4
I'm pretty sure it's subfloor. It looks just like the subfloor in the rest of the house. There were a couple of layers of thin plywood above it that we took off with the vinyl, maybe that was luan underlayment? I don't know what it is.
Old 01-21-2012, 05:49 PM   #5
Just to be clear, it was vinyl, thin plywood, More vinyl, more thin plywood, and then this floor you're seeing here.
Old 01-21-2012, 06:03 PM   #6
Tech Dawg's Avatar
Good answer! You can cut that section, joist to joist, add additional blocking and attatch new plywood.
Then your CBU or crack isolation membrane
*be sure your cbu is set in a bed of notched mortar
Todd
www.aloneeagle.com
Old 01-21-2012, 06:22 PM   #7
Okay...I guess my real question is, do I have to? What happens if I don't?
Old 01-21-2012, 06:29 PM   #8
Tech Dawg's Avatar
If the ply is rotted, moldy and flexy then yes. If its just a dried out water stain and the ply is solid it may be ok. That's your call since we're only seeing a picture..
Todd
www.aloneeagle.com
Old 01-21-2012, 06:55 PM   #9
How can I tell if it's rotted? It's not mushy or flexible or anything, or even damp, but it is kind of dark.
I guess better safe than sorry and replace it, but we have a lot to do and I'm just trying not to add to the list if don't have to.
Old 01-21-2012, 07:09 PM   #10
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
If the plywood is rotten, the toilet is going to keep working itself loose again and eventually leak.
titanoman is offline   Reply With Quote
Old 01-21-2012, 09:20 PM   #11
Rewards Points: 14,312
Looks like black mold to me.
Hit it with some bleach and water and see it gets a lot lighter.
Subfloor in a Flood Zone lukew Flooring 8 02-18-2011 07:43 AM
Subfloor repair around toilet? b_corwin Building & Construction 16 02-04-2011 04:14 PM
Replace subfloor? robtrevino Flooring 10 01-03-2011 08:43 AM
Subfloor Help Tom5151 Building & Construction 16 09-24-2009 12:33 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
