-   -   should I replace this subfloor? (http://www.diychatroom.com/f5/should-i-replace-subfloor-130894/)
bublsort 01-21-2012 06:34 PM
1 Attachment(s)
Hi all,
We took out the vinyl flooring toilet in a rarely used bathroom in order to do some tiling, and found some very water-stained subfloor. It didn't feel wet or any different really from the rest of the subfloor. Do we need to replace this section of subfloor? What do you think?
Thanks a lot.
Attachment 44443
bublsort 01-21-2012 06:35 PM
Vinyl flooring AND toilet, sorry.
Tech Dawg 01-21-2012 06:43 PM
Is that the subfloor or luan underlayment?
Todd
www.aloneeagle.com
bublsort 01-21-2012 06:46 PM
I'm pretty sure it's subfloor. It looks just like the subfloor in the rest of the house. There were a couple of layers of thin plywood above it that we took off with the vinyl, maybe that was luan underlayment? I don't know what it is.
bublsort 01-21-2012 06:49 PM
Just to be clear, it was vinyl, thin plywood, More vinyl, more thin plywood, and then this floor you're seeing here.
Tech Dawg 01-21-2012 07:03 PM
Good answer! You can cut that section, joist to joist, add additional blocking and attatch new plywood.
Then your CBU or crack isolation membrane :rockon:
*be sure your cbu is set in a bed of notched mortar
Todd
www.aloneeagle.com
bublsort 01-21-2012 07:22 PM
Okay...I guess my real question is, do I have to? :) What happens if I don't?
Tech Dawg 01-21-2012 07:29 PM
If the ply is rotted, moldy and flexy then yes. If its just a dried out water stain and the ply is solid it may be ok. That's your call since we're only seeing a picture..
Todd
www.aloneeagle.com
bublsort 01-21-2012 07:55 PM
How can I tell if it's rotted? It's not mushy or flexible or anything, or even damp, but it is kind of dark.
I guess better safe than sorry and replace it, but we have a lot to do and I'm just trying not to add to the list if don't have to.
titanoman 01-21-2012 08:09 PM
If the plywood is rotten, the toilet is going to keep working itself loose again and eventually leak.
joecaption 01-21-2012 10:20 PM
Looks like black mold to me.
Hit it with some bleach and water and see it gets a lot lighter.
