Should I Keep Grinding My Floors? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 06:00 PM   #1
Should I keep grinding my floors?
I am putting down an epoxy floor and wanted to level my garage floor. Apparently I used the wrong stuff and put down a self leveling underlayment instead of a self leveling topping. It had ridges but was fairly level. I wanted to get rid of the ridges and someone on here recommended that I rent a floor grinder to grind them off. As I'm doing so, the ridges are gone, but the blue primer is showing through in many places. The epoxy will cover this up but here's what I'm wondering. Obviously, I no longer have one continuous coat of the concrete on top of the primer. Do I need to keep grinding until it is all gone? Also, is the primer a sealant? Do I need to keep grinding until all the blue is gone? The primer is rough because of the stone I'm grinding with so will the epoxy primer stick to it? Please help. I have to get this done tonight so I can return this equipment tomorrow. Thanks.
Blake
SBlakeS is offline   Reply With Quote
Old 03-03-2010, 06:08 PM   #2
One other note. I used Mapei Novaplan 2 and the primer is Mapei 1K.
Old 03-03-2010, 09:25 PM   #3
well, I grinded as much as I could. There is still a little blue but oh well. It's porous so I think the epoxy primer should stick fine.
Old 03-05-2010, 08:39 AM   #4
I know it's too late, but I think it will work fine for you.
Dairylander is offline   Reply With Quote
Old 03-25-2010, 01:38 PM   #5
Thumbs up
Grinding
The key issue in your case is not whether there is a little of the old material on the surface. It is whether the surface is porous. Splash a few tablespoons of water in various areas. If the concrete turns dark quickly you are good to go. If it beads up, you've got more grinding to do.
You will probably be OK even if there is a small percentage of the old material on the floor IF the grinder has scuffed up the surface so that a good quality epoxy has something to grab onto. (Don't go with the cheap stuff. You will regret it later.)
Patrick Dowd
California Concrete Restoration
http://www.squidoo.com/epoxygaragefloors
calconcrete is offline   Reply With Quote
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 09:50 AM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 05:21 PM
damage to prefinished floors normal during a remodel? zzman Remodeling 15 12-04-2008 06:25 PM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 06:59 PM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
