Should I Fill The Gaps? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-09-2010, 07:41 AM   #1
Should I fill the gaps?
I laid 1/2' plywood as a new substraight over my old 3/4" t&g plank subfloor. The finished floor will be carpet. I left about an 1/8" gap between sheets. I later noticed that my helper friends were a bit liberal with the 1/8" gap theory in a few spots. I was wondering if filling all the gaps with something flexible like 100% silicone would be ok? Would it still allow proper expansion? Or would the silicone bead want to get pushed up and out of the gap, or completely defeat the purpose of leaving the gaps?
Thanks for any thoughts
TReally is offline   Reply With Quote
Old 03-09-2010, 08:06 AM   #2
the Musigician
DangerMouse's Avatar
If you're putting down carpet, I wouldn't worry about it.
DM
Proper methods to fill concrete gaps, holes, cracks and resurface concrete jzam42 Building & Construction 6 07-21-2010 12:50 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
How to fill gaps in cement backerboard? tripower Building & Construction 5 06-27-2009 04:31 PM
How to fill gaps in hardwood floors ponch37300 Flooring 2 04-16-2009 05:30 PM
Gaps in drywall. What to use to fill them in. yummy mummy Building & Construction 13 01-02-2008 01:19 PM
