Should I Carpet My Stairs To Basement With Berber? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2009, 12:33 PM   #1
Dave
Send a message via Yahoo to schreibr53
should I carpet my stairs to basement with berber?
I've read a lot about it. I understand that the olefin layer that binds the loops together loses its memory over time and sags when stepped on in the same location. What more should I consider before using berber to carpet stairs?
schreibr53 is offline   Reply With Quote
Old 07-21-2009, 06:36 PM   #2
Floorwizard's Avatar
if durability is the most concern then get yourself a Nylon Berber.
Small tight loops is best.
Floorwizard is offline   Reply With Quote
Old 07-22-2009, 06:19 AM   #3
ccarlisle's Avatar
Most "berbers" are made of polypropylene, a type of plastic, and therefore does not provide any potential for mould. That's why it is recommended in basements - and not everywhere. For water-based soils, it cleans relatively easily but for oil-based soils it's hard to clean. Polypropylene repels water but absorbs oils, so watch out what you spill. The weave of a berber being tight loops makes hot water extraction tough to use to clean it because of the reduced airflow up the vacuum hose...
And as already pointed out, its resilience isn't the best.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Tags
berber carpet stairs
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 09:24 PM
Carpet on Stairs, Hallway: Nap Direction Carol Emmarie Flooring 5 03-26-2009 11:40 AM
