#1 |
Should concrete be sealed before tiling?
I have a concrete floor that is unsealed and would like to lay tile over it. It looks to have been poured after the walls were built or it was an old porch that was incorperated into the house. When it is wet outside, the concrete smells very musty and seems to draw moisture. I was wondering if I can seal it first and then use one of those membranes between it and the new floor?
#2 |
Contractor
Use Drylok masonry waterproofer
Dan101 Owner J.& D. Remodeling Chicago, IL |
#3 |
if you seal it there is a chance that the thin set won't stick very well.
| The Following User Says Thank You to DannyT For This Useful Post: | joecaption (10-10-2012) |
#4 |
+1 What DannyT said.
#5 |
Doer of Many Things
You have to use very specific products that are designed to have flooring installed over them. Bone Dry is probably one of the easier ones to use.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Tiling basement on concrete slab- Use uncoupling underlayment or not? | NewHomeDIYGuy | Tiling, ceramics, marble | 13 | 03-27-2012 09:44 AM |
| Self adhesive vinyl tiles on new (un sealed) concrete? | danster44 | Flooring | 15 | 03-19-2012 03:57 PM |
| Tiling over concrete in basement bathroom | moormancm | Flooring | 0 | 02-20-2012 10:21 AM |
| Tiling concrete outdoor table | kathy k | Building & Construction | 1 | 08-09-2009 07:49 AM |
| Tiling over new concrete | 47_47 | Tiling, ceramics, marble | 2 | 12-12-2008 02:49 PM |
