Shorter Screws For 1/4" Hardibacker? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 01:24 PM   #1
Shorter screws for 1/4" Hardibacker?
I have radiant heating tubes running under my subfloor. When installing the backer board it is painful, impossible in some situations, to try and hit joists for every seam. We are using thinset to set the backer board in. I have used 1-1/4" screws on every joist, but there are a few locations where a shorter screw would be nice. Say 3/4" - 1". Any chance I can find a shorter screw that will work in this situation?
yogi_bear_79 is offline   Reply With Quote
Old 01-10-2012, 11:31 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 224
Hi Yogi,
You are not supposed to hit the joists when installing the backer, it's fastened into the subfloor. 1 1/4" wouldn't penetrate the joists much anyway. You can use roofing nails instead of the screws. But 3/4" fastener is too short. I'd stay with 1 1/4". Your tubes aren't that close to the subfloor is it?
Jaz
Old 01-11-2012, 10:17 AM   #3
Jaz,
Thanks for the reply. Yes the tubes are ONIX by Watts and they are stapled directly to the underside of the subfloor.
Countersinking screws into Hardibacker billyg Flooring 7 09-27-2011 10:09 PM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 08:34 PM
uneven seams with hardibacker after thinset and screws wpeckler Tiling, ceramics, marble 0 03-03-2011 02:25 PM
Can I use deck screws with Hardibacker? spaceman spif Kitchen & Bath Remodeling 10 10-26-2010 03:11 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 09:56 AM
