Shopping Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 04:44 PM   #1
Shopping laminate flooring
This is my first post here, and I'm hoping to get some help regarding hardwood-laminate flooring. We decided to go the direction of hardwood laminate because of it's durability w/ children & pets. However, their appears to be a broad range of options out there & we're not sure what characteristics are most important to look for when purchasing such a floor. When I review the specifications, what specific characteristics should I be looking for if I want a durable product that will resist stains, moisture, laminate chipping, etc?
Also, what price should I expect to pay per sq. ft. if I'm looking for a product that meets the above criteria?
Finally, what are your thoughts regarding products that have built in pads vs. installing separate pad & floor?
Thanks!
jdh2 is offline   Reply With Quote
Old 02-22-2010, 07:51 PM   #2
Lowriderchic's Avatar
I have the same questions We are doing a kitchen and like you said there are wayy too many brands, finishes, etc.
Lowriderchic is offline   Reply With Quote
Old 05-13-2010, 10:28 AM   #3
ews
Portlander
ews's Avatar
If you have kids or pets then laminate flooring is going to hold up the best. Way better than conventional hardwood flooring because it will not scratch easily. Especially so with dogs. Your conventional oak hardwood will look like a skating rink in just one month with "man's best friend" living with you. Urine can mess it up though ----> Please Help!!!! Pet Urine and Laminate Floors
You can check out this laminate flooring website if ya' need more help.
ews is offline   Reply With Quote
Old 05-13-2010, 11:14 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
Never wet mop a laminate floor. And never, ever use a Swiffer Wet Jet on a laminate.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-14-2010, 05:49 AM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
There are a lot of good brands out there. I personally feel Wilsonart has one of the best laminates on the market. Their High Impact product are especially good with a wear layer far thicker than any other brand I've seen. Wilsonart also tends to be one of the pricier laminates though unless you find a good sale.
poppameth is offline   Reply With Quote
Old 05-20-2010, 08:10 PM   #6
Never ever use a swiffer wet jet on a laminate floor????? Would like to know why . Just bought one but.....its still in the box.
Old 05-20-2010, 09:11 PM   #7
Rewards Points: 148
According to some flooring inspectors, they put out enough moisture to ruin laminate.
Old 07-01-2010, 05:09 AM   #8
finance geek
what if the laminate flooring has water resistant coating?
swaption is offline   Reply With Quote
Old 07-01-2010, 11:44 AM   #9
Handyman
Rewards Points: 512
The swiffer sweeper works great if you dampen the head but the swiffer wet jet actually allows you to squirt out a cleaner solution...BIG no no
canadaclub is offline   Reply With Quote
Old 07-01-2010, 12:44 PM   #10
Do work
Rewards Points: 81
I just bought some flooring. I ended up buying solid hardwood. But when I was at the flooring store I look at several laminates. Many were make in China. I knew I didn't want to put any of those in my house. Almost all of the cork and bamboo ones where from China.
liquidvw is offline   Reply With Quote
Old 07-03-2010, 10:50 PM   #11
finance geek
what's wrong with the ones from China. i thought it only pertained to drywall.
Old 07-05-2010, 07:28 AM   #12
Do work
Rewards Points: 81
Everything is wrong with China. Bunch of cheap crap made by slaves. I'd rather have no floor then a floor from China.
Old 07-05-2010, 07:53 PM   #13
Rewards Points: 271
I would not do it. I am not trying to plug Lowes but I did this recently and shopped around a lot. I saw all the China stuff too. I wanted strip plank but it usually is not hard enough unless you lay down tons of urethane or get a species of wood that is hard. The bottomline was that would be $7 a foot installed.
So I had to look at laminate. I ended up getting Swiftlock Plus from Lowes at $2.29 a foot less 10% coupon. Beveled edges and a graining that looks real, its own cushion plus made in either Canada, Germany or the USA. It has a 20 or 25 year warranty and 10 year light commercial.
http://www.lowes.com/pd_295647-42870...029_4294937087_
They have other colors. it is the best laminate I have seen due to the graining and beveled edges.
No wood in kitchens and be very careful with water.
Frank Lardino
FrankL is offline   Reply With Quote
Old 07-05-2010, 08:06 PM   #14
Rewards Points: 271
The best deal I have seen is at Lowes. You can get a gallon of Pledge for wood floors. I think the cost is just under $10. You can use a foam squeege type mop or regular mop. Sweep or vacuum then use the Pledge.
http://www.floorcareproducts.com/cle...loor/index.asp
No water. It gets in the edges of the laminate.
Frank Lardino
Old 08-14-2011, 05:48 PM   #15
Rewards Points: 16
has anyone used the swiftlock vinyl planks from Lowes?
keithl1967 is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 12:04 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 09:01 AM
