Old 09-17-2008, 07:03 PM   #1
Shoe Moulding?
I've been shopping for laminate to install myself. I assumed I would get shoe moulding that matched, but a local store is recommending paint grade, painted to match the baseboard.
What do you normally use? One concern that I do have with the matching shoe, is that it all appears to be MDF with a cheap vinyl 'contact paper' applied (I could peel it off the back side with my finger nail). Does that hold up to brooms and vacuums etc. banging into it?
Thanks...
Gary
garyoutwest is offline   Reply With Quote
Old 09-17-2008, 07:06 PM   #2
Shoe Moulding?
I bought the white plastic/composite shoe from HD and painted it white to match baseboard. Looks good against the new hardwood floor. Make sure you paint it first before installing unless you've a very steady hand or a lot of masking tape.
bob22 is offline   Reply With Quote
Old 09-17-2008, 10:53 PM   #3
Moderator
Termite's Avatar
Shoe Moulding?
If you have painted base, painted shoe is the way to go. Looks much better that way.
Old 09-21-2008, 12:20 PM   #4
ngs
Shoe Moulding?
The shoe, or quarter round if you use that, is part of the base board system, not part of the floor system. Think if you had, say, a green painted floor and white baseboard, you would probably not think of doing the shoe in green. Prime first, then one coat of finish paint, then install, then fill nail holes and caulk (top of shoe only, not to the floor, the crack between wood floor and colored base in natural looking and not noticeable) then one light 2nd coat to cover caulk and nails, beeeaautiful!
ngs is offline   Reply With Quote
Old 09-23-2008, 04:03 PM   #5
Drywall contractor
Shoe Moulding?
Agree with all of the above, especially using composite (plastic) for tiled areas that get exposed to moisture on a regular basis from mopping. When I pulled up the original stuff in my kitchen for a new floor, there were pieces that were close to falling apart.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
1950s ranch tub - 3" tub drain shoe needed! ranchgal Plumbing 2 09-13-2008 08:04 AM
Need tips for installing/painting moulding BradG Painting 3 02-04-2008 01:44 AM
Moulding options for badly warped wall? marc205 Flooring 4 01-21-2008 08:43 AM
Is it best to caulk new moulding edges before painting? Davo Painting 8 04-15-2007 12:12 AM
