Sheet Vinyl Over Parquet Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-24-2007, 09:43 AM   #1
Rewards Points: 83
Sheet vinyl over parquet floor?
Can I put sheet vinyl over a parquet floor? Should I scuff it up first with sandpaper? Maybe put luan down before hand? What do you think?
AllGoNoShow is offline   Reply With Quote
Old 10-24-2007, 12:47 PM   #2
Why would you want to? Parquet is a much nicer floor.
Concordseeker is offline   Reply With Quote
Old 10-24-2007, 02:48 PM   #3
Rewards Points: 83
In my neck of the woods it is generally considered ugly and way oudated.
Old 10-24-2007, 03:31 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
You're right most parquet floors are dated. You need to remove the parquet down to the subfloor, don't put anything over it.
What type of room is this?
Jaz
Old 10-25-2007, 08:59 AM   #5
Rewards Points: 83
Jaz
It is in a 6x10 foot bathroom. Ripping it up should be fun....is there any tips to getting the glue off the subfloor (and the "subfloor" in this house is actually strip oak flooring attached directly to the joists-thats how they did it back in 1930)
Old 10-25-2007, 11:23 AM   #6
Tileguy
JazMan's Avatar
Rewards Points: 388
Don't worry about the adhesive, you'll have to install new plywood over it anyway. Just knock off any high spots. After you re-screw to sub. you can decide how thick the underlayment needs to be. Choose 3/8" or thicker. Make sure it's rated as an underlayment and the plies are bonded with exterior glue.
Jaz
Old 10-26-2007, 10:09 PM   #7
Floorwizard's Avatar
Excellent advice.
Floorwizard is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Tiling over sheet vinyl frskelly Flooring 9 11-07-2011 10:54 PM
tile on vinyl floor. jkbitner416 Remodeling 6 01-23-2007 06:46 PM
big mess on vinyl floor installation thecanadian Flooring 1 03-19-2006 07:28 PM
