Sheet Vinyl Flooring Removal
This question may have been posted and replied to before but I could not find any answers when searching, so…
We have a home constructed in 1992 that has sheet vinyl in our kitchen (approximately 124 SF). We are planning to remove the vinyl so we can screw down the sub floor to eliminate a few squeaks and stabilize the floor (there is not a lot of movement in it) and install Dura Ceramic tile above it.
So the question, what is the best way for a DIY to removal sheet vinyl? FYI, if it matters, it appears that the vinyl was not perimeter glued, but glued under its entirety.
We were told to use a wallpaper remover with a lot of replacement blades and slowly do small sections at a time to make sure we remove all vinyl down to the sub floor, It was also suggested that the job could take up to four hours if done right.
Any suggestions or thoughts or experiences on how to do this are very welcome.
Couple of extra questions, would it be worth my while to buy and use a heat gun to do this? How do the pros removal sheet vinyl? Are there different or better tools to do this work than I have listed?
Thanks very much and have a great Thanksgiving!
