#1 |
Sheet vinyl bubble
Had some sheet vinyl installed (perimeter bond) and there's a small (maybe 2" x 8") section where the vinyl is slightly bubbled. It's right where the sheet was folded back when the installer (a relative; yes, I know) glued the first half of the perimeter.
So I call the installer and he says "Don't worry, wait a couple days, it'll settle down". It's now been 2 months it's still the same. The last time we spoke he said "You can hardly notice that bump" and made it seem like I was being unreasonable. Maybe I am, but that bubble is right in the middle of the floor and bugs me. A friend said he read about using a hypodermic needle to poke a hole and remove the air and then inject some glue. Is this standard practice? I'm guessing that sheet vinyl adhesive would be too thick to inject with a needle, so any ideas on what type of glue would be best? Thanks very much for any help. |
#2 |
remodeling pro
Sheet vinyl bubble
Poking a tiny hole is commonly done to relieve air bubbles in both vinyl floring and wall paper. Pick a spot in the pattern that will be difficult to see, such as the junction of color changes or designs, as the hole may need to be a little larger than a needle poke. If the needle doesn't work , it maybe necesary to use a tiny drill bit. Chances are the adhesive in this spot is still not cured, so once you release the air pocket, you can probably roll the bubble down and have it stick.
#3 |
Sheet vinyl bubble
Thanks for the help, troubleseeker. I'll poke a hole and see what's what. I appreciate the feedback.
#4 | |
Tileguy
Sheet vinyl bubbleQuote:
#5 |
Sheet vinyl bubble
Hi Bud,
Thanks for the reply. It's perimeter-glued. It may be stretched, I don't really know. A friend who has a bit of experience in this dept. guessed that when the installer laid the second half down onto the adhesive, he didn't pull the sheet evenly, which resulted in a slight buckling on one side, which left the bubble. Thanks also for the tip on the syringe. Seems like that would be a rather large needle, but it might be necessary. |
#6 |
Tileguy
Sheet vinyl bubble
Insert the needle at a steep angle, (5 or 10 degrees off the floor plane) inject the adhesive, pull the needle out. Roll the area to spread the adhesive under the material.
If the roller doesn't make the needle penetration disappear then heat the vinyl at the injection site with a hair dryer and roll over the hole, it will usually close. If this is a distortion (in the vinyl) then getting it to stay flat may be a problem. The adhesive could take days to dry also. I would use a book or something flat to sit on the site and maybe even a chair leg or a brick to weight it down. Once vinyl is stretched it can have a memory and may not be totally repairable.
#7 |
Sheet vinyl bubble
Great information, thanks, I'll give this a try. I'm concerned about the distortion and the fact that's it's been two months since the install, but it's worth a shot.
| Display Modes | |
| Tiling over sheet vinyl | frskelly | Flooring | 9 | 11-07-2011 11:54 PM |
| Sheet Vinyl Flooring Removal | yoods | Flooring | 2 | 11-22-2007 01:04 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 1 | 03-19-2005 01:55 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 0 | 04-18-2004 04:35 PM |
