Sheet Vinyl In A Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 07-29-2009, 10:22 AM   #1
sheet vinyl in a bathroom
Redoing my sons bath and using sheet vinyl on the floor.
All the installation advice mentions 1/8 gap for expansion. What do you do at around the tub edge? I'd like a clean finish.
Will I use caulk or a 1/4 round or just a snug fit.
Jack
JackVa1 is offline   Reply With Quote
Old 07-29-2009, 11:47 AM   #2
Rewards Points: 258
I bring the vinyl to within 1/16 to 1/8 of an inch of the tub and then use a thin bead of silicone caulk. My goal is to have an unobtrusive, water tight joint (so water can't get under the vinyl due to dripping when leaving the tub) and this method accomplishes both goals.
retired guy 60 is offline   Reply With Quote
Old 07-29-2009, 12:03 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Most homecenters sell a plastic strip to cover that. It looks like a narrow piece of cove base and is peel and stick.
Old 07-29-2009, 01:00 PM   #4
I guess I could try the bead and use the plastic cove as a back up if I screw up or am not happy with the look. Thanks, guys
Old 07-29-2009, 01:17 PM   #5
Floorwizard's Avatar
It's called cove strip and it looks better than 4 inch high cove base.
Floorwizard is offline   Reply With Quote
seal seams on self sick tiles NoExperience Flooring 3 08-12-2008 08:25 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
