Old 12-30-2012, 03:39 PM   #1
seansy59's Avatar
Shed Flooring
Basic old 10x12 shed floor, 3/4" pressure treated ply. It is 7 years old, so the bare plywood is stained and dirt marks......making it not possible to just throw a clear coating over it..
I currently have 2 year old vinyl flooring which is ripping, and a throw carpet in the middle. In a year, it will be insulated and AC/Heated. It is used for storage and a small work area/hangout......
What should I do with the floor? I want it to last more than 2 years care free
Carpet?
Stain it?
Paint it?
Thanks......
seansy59 is offline   Reply With Quote
Old 12-30-2012, 03:45 PM   #2
woodman58's Avatar
Shed Flooring
I would put commercial vinyl tile, 12x12's. With a good coat of wax it will be good for several years. And then just stripe and wax it again, as needed.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 12-30-2012, 04:39 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Shed Flooring
Probably would have to put down 1/4" plywood underlayment to get the tile to stick. It won't stick to a dirty maybe oily floor.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 01-02-2013, 06:54 PM   #4
seansy59's Avatar
Shed Flooring
Okay.....well, as long as no one else has any objections...........I rather not go vinyl since it is slippery and rips easily....
I'm going to sand the floor smooth, clean it well, stain the floor, and polyurethane the floor. I'd like to stain the ply a nice natural oak wood color.
A few questions.
1. Oil or water based stain?
2. Oil or water based polyurethane? And which may cause the floor to be more slippery? Which one would last longer?
Thankyou!
Old 01-06-2013, 12:41 PM   #5
Shed Flooring
I would do an oil based stain and an oil based poly. However, if you are really concerned with it being slippery you might consider doing the oil based stain, a coat of oil based poly, then 2 finish coats of anti slip bona traffic water finish. Using this combo would be sure to not be very slippery and it would be very durable. The only downside would be buying all of this different stuff and the Bona traffic is $100 per gallon. Although, 1 gallon would easily do multiple coats.
Awoodfloorguy is offline   Reply With Quote
Proper transition between shed roof and shingled roof? aribert Roofing 9 04-12-2012 04:17 PM
Conduit questions in shed wiring TheCowGod Electrical 28 03-18-2012 02:42 PM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 12:35 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
