Old 05-03-2011, 01:14 PM   #1
Separating floors
We have floating floors throughout our LR/DR/KIT. Our kitchen floors are beginning to seperate in three or four spots. Is this common, and how hard of a fix is it? It squeeks in several spots too which is very annoying. Any advice would be very much appreciated.
amberd521 is offline   Reply With Quote
Old 05-03-2011, 08:55 PM   #2
woodman58's Avatar
Separating floors
If this was a DIY job your in trouble. More than likely the floor was not flat enough to install laminate. To fix this you will have to take the floor apart, level the floor, and replace the laminate. If you had someone else do it then have them come and fix it. If the floor was flat to within 1/8" in 10' the problem could be moisture. If this is moisture there is no fix.
woodman58 is offline   Reply With Quote
salvaging the floors under glued down hardwoods christymichael General Discussion 5 03-07-2011 08:31 AM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 09:50 AM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 05:21 PM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 06:59 PM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
