Old 06-26-2009, 11:33 PM   #1
semi transparent stain on interior concrete floor
My husband and I pulled out the carpet in two bedrooms and want to stain the concrete with a semi transparent stain. We pulled up the carpet tack boards and nails. I washed the concrete with a degreaser. The nails left divets in the concrete which we patched with QuickCrete.
The patched areas need to be smoothed even with the surface and there are still paint drops (from original construction) that have to come up. What is the best way to proceed? Is there a certain type of cement sander that will take care of both of these things? Is an etcher needed if the surface is clean of everything but paint droplets? Any suggestions will be appreciated. Karen
Karen Crisco is offline   Reply With Quote
Old 06-27-2009, 06:54 PM   #2
Tileguy
Bud Cline's Avatar
Here's what you are wanting to do and everything you could ever want to know about doing it. You can also buy the supplies from this gal.
http://www.gayegoodman.com/
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 05:06 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Hazy dusty look on hardwood floor lleegle Flooring 4 07-26-2008 11:04 AM
How to level basment floor and keep floor drain Bcoleman6 Flooring 2 07-20-2008 07:23 AM
