Semi Polished Limestone Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 09:01 AM   #1
Semi polished limestone tiles
Hi
I have had new semi polished limestone Floor tiles laid. Unfortunately they were not cleaned properly before 2 coats of sealant was applied. You can see swipes of a floor mop.
Can they be sanded back to tile or does the sealant have been stripped off. Please can anyone help.
Carndonagh is offline   Reply With Quote
Old 01-07-2009, 01:09 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
I'd call the manufacturer of the sealant and ask them the best way to remove the sealant. They should offer a product that will do the trick.
Then I'd be sending a bill to your tile setter!
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-07-2009, 01:25 PM   #3
messed up semi polished limestone tiles
Hi thanks for response. I think it does say on the seantant bottle what product to use to strip sealant. Tiler has supposedly corrected mistake. But it looks worse, no idea what method he used but obviously need to speak to him but need to get over huge disappointment.
Carndonagh
Old 01-07-2009, 06:12 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
As rocks go, limestones can be very porous and I would hesitate using any stripper that would reduce the sealer to an emulsion and then carry it deeper into the stone. That's probably what has happened now.
I would try sanding the surface, I don't think it will hurt anything and will remove the sealer at the surface. Once you sand one tile you'll be sanding them all I'm sure because sanding will alter the surface texture of the stone.
Old 01-08-2009, 08:03 AM   #5
Thank you Bud Cline for response. A store cupboard was also tiled in the semi polished limestone tile. I think I will test a couple of tiles there by sanding and doing another couple by stripping. I have been given mixed advice, so perhaps I should try both.
Many Thanks
Carndonagh
Old 01-08-2009, 09:56 AM   #6
angus242's Avatar
Yep, Bud has a very good point!
However, I just went through a similar situation. The sealant was Aqua Mix and they suggested a stripper. This was on tumbled travertine. Their solution worked. It removed the surface sealant residue. However, they said because of the sealant that absorbed already, no other sealant could be used. Worst case, just more of the original. I assumed the same situation would apply to you. I still suggest you contact the manufacturer to see what they have to say and for pete's sake, don't let the tile guy touch it any more!
Angus
My Albums
Old 01-08-2009, 02:49 PM   #7
semi polished tile
Hi Angus 242
I have emailed supplier of tile. If do not hear anything tomorrow I will ring them. They are small company and have been a great help in the past.
Sounds like your problem was the same as mine. Will let you know what supplier says. By the way the tiler did excellent work at tiling but I cannot understand why the rest went so wrong.
Thanks again for help
carndonagh
Old 01-13-2009, 05:07 PM   #8
manufacturers response to limestone tiles
Hi Angus 242 and Bud Cline. The supplier of my Limestone tiles got back to me. He says I need to use a sealant stripper and start again.
Many thanks to you both for help.
Regards
Carndonagh
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Stains on polished porcelain tiles tommurphy73 General DIY Discussions 4 12-24-2007 12:03 PM
resealing limestone tiles yummy mummy Building & Construction 3 11-13-2006 08:30 PM
resealing limestone tiles? yummy mummy Flooring 6 11-13-2006 09:05 AM
How practical are limestone tiles in a shower? lizgamble Remodeling 2 09-15-2006 09:46 PM
