Self-stick Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 08:16 AM   #1
Rewards Points: 2,238
Self-stick floor
We're putting a self-stick floor in a kitchen - not "cheap" stuff.
Had to be done - NOW!
I don't think they got the temp. up high enough; or, long enough -
having problems to get the flooring to "settle down".
Some type of glue/mastic we can use?
Heat gun?
Roller?
Some of the above?
Thanks!
rossfingal
rossfingal is offline   Reply With Quote
Old 11-04-2012, 08:24 AM   #2
DIY staff
Rewards Points: 7,174
Henry's Bond enhancer should have gone on first-----
To late now-----heat will help and a roller----you have a torpedo heater?
Rusty might know a trick or two----I always use bond enhancer before starting---cures dust and adhesion problems----
Old 11-04-2012, 08:48 AM   #3
Thanks for the response!
Sub-floor is fine.
We used leveler where necessary - not too much, needed.
The whole floor got hit with "Bond-Enhancer".
I've got heaters in there.
Should have had the heaters in there days before this "escapade"
started!!
I don't "specify" - I install what someone tells me to!
What type of roller?
Thanks!
rossfingal
Old 11-04-2012, 09:25 AM   #4
DIY staff
Linoleum roller----rent one---Century tile has them--Home depot may---they do sell them --look next to the tile section---they are with the floor scrapers----to expensive for a one time use---rent---
Old 11-04-2012, 09:27 AM   #5
Rewards Points: 13,260
Hope you got it in writting there's no warrenty.
Old 11-04-2012, 09:31 AM   #6
DIY staff
Joe---this is Illinois---We make things work here---Just like you do----
Chewing gum does not work---call century tile and see if they have an adhesive for peal and stick----just remember that those sales people don't really know what they are talking about----Rusty?
Old 11-04-2012, 10:07 AM   #7
I learned the hard way long ago, If I know it's not going to work, do not do it.
Funny how short there memery gets when it fails.
I like people to say who did this for you, not who did this to you.
Just love it when it fails and they call you back and expect you to make it work and not have to pay you, then tell all there friends what a poor job you did.
rossfingal (11-04-2012)
Old 11-04-2012, 10:12 AM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Use clearspread adhesive like you would for any vinyl tile. Then roll with a 100 lb roller. Just make sure it is a very, very, very, light layer of adhesive. Use the back side of the trowel. No notches.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
oh'mike (11-04-2012), rossfingal (11-04-2012)
Old 11-04-2012, 10:28 AM   #9
Thanks! "RB"!
I thought as much - just wanted to get some "pro" opinions!
I don't; or, haven't done too much of the "self-stick" stuff!
At least - actually - it looks pretty good!
Thanks!
"RF"
The Following User Says Thank You to rossfingal For This Useful Post:
Old 11-04-2012, 11:15 AM   #10
Thanks people!
Particularly "RB"!
"jc", "M" - thanks too!!
Maybe my problem is solved!
(At least I've got something to show the "powers-that-be" -
see what these people say!)
"RF"
Old 11-07-2012, 03:45 AM   #11
A follow-up.
Well: the "powers that be", did not want to "spring" for a roller.
However, the use of "glue" (thanks "RB"!) -
A heat-gun -
A soft, rubber mallet -
Did the trick!
Next time -
It will be, what I wanted to do in the first place -
Sheet-goods!
It does look pretty good, now!
Thanks again people!!
rossfingal
oh'mike (11-07-2012)
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
leveling floor for peel and stick tile Truckerswife Flooring 5 03-25-2011 07:59 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 07:49 PM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 09:59 PM
