Self Stick Carpet Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 06:44 PM   #1
I'm seeing these self stick tiles (were popular back in the 70's). Has anyone used these recently?
I'm guessing these need to go over a clean subfloor. Haven't looked into this that much to learn if there's anything that should be layed over the subfloor before applying the carpet tiles. Just want to change a small room and a do it yourself project.
Any suggestions? Like hire a carpet installer and install carpet on a roll?
Jo Jones is offline   Reply With Quote
Old 02-05-2013, 07:46 PM   #2
747's Avatar
Rewards Points: 534
For a small room something like Berber carpet tiles. Why not definitely diy friendly not big money. What is on the floor now in the room. If carpet you will need to remove then the pad underneath. Get some needle nose pliers to get staples out of pad.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
Jo Jones (02-06-2013)
urrghhh vinyl stick tiles princelake Flooring 17 03-11-2012 04:53 PM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 07:04 AM
Use cork tiles under basement carpet Tech7 Flooring 2 03-20-2011 07:15 PM
How do I place marble flooring when I have self stick tiles right now? Jezka121102 Flooring 1 08-23-2008 11:06 PM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 01:04 AM
