Self Levelling Concrete Or Precision Grout? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2008, 01:21 PM   #1
Self levelling concrete or Precision Grout?
I'm putting a fireplace insert into my masonary fireplace.
The hearth extension must now be 19.5" (it is 16" at the moment). I've remove the existing tile along with the concrete bed. The fireplace is built over a counterlevered slab poured at the same time as the original foundation. I've cut a portion of the hardwood to the required dimension but now I need to make everything level for the new tiles.
What product should I use? The thickness needs to be between 1" to 3/8" and it needs to be non combustible.
Tx for your help,
Yves
svey is offline   Reply With Quote
Old 02-21-2008, 02:12 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Either product you mentioned and several you didn't mention will work. The trowelable products may produce a challenge that the Self Levelling Compound would not but the SLC would likely have to be temporarily formed.
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
