Self Leveling Concrete Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 11:35 AM   #1
Self leveling concrete questions
I need to float self leveling concrete into a 14'X12' room approximately 1/2" to 3/4" thick. How can I mix this amount of SLC? Can I just mix it in buckets and put it down in several layers?
There are a few small high spots in the floor. What is the best way to knock down the high spots in concrete?
Dave
Dave K is offline   Reply With Quote
Old 08-20-2011, 11:46 AM   #2
DIY staff
Rewards Points: 7,174
Obviously read the package instructions---
Sand can be added to the mix for high build ups---Material must be added in layers--to much at once and it will crack--
Most require a primer coat before the SLC goes down to insure a good bond.
Some suggest a liquid latex be mixed into the first coat.
A jack hammer could be used to knock off the high spots--also an angle grinder with a diamond cup works well .
My go-to SLC is Jifset and Linewebbers liquid---However that is only because I know its quirks --
There are many good brands.
Old 08-20-2011, 11:57 AM   #3
DIY staff
Bud--your 2 cents is needed.
Old 08-21-2011, 06:49 AM   #4
Rewards Points: 200
ARDEX Engineered Cements
Floor Doc is offline   Reply With Quote
A couple of noob concrete finishing questions SMRcalidiv Building & Construction 11 07-31-2011 08:27 PM
Leveling uneven floor - laminate over concrete siggyfreud Flooring 1 07-01-2011 05:57 PM
Plastic shower base and concrete / leveling issue JoTeeBee Kitchen & Bath Remodeling 2 06-17-2011 08:46 PM
Leveling Concrete mark! Building & Construction 4 01-01-2011 10:14 PM
Concrete questions Focus2005 Building & Construction 1 05-31-2005 06:05 PM
