-   -   Self leveling concrete questions (http://www.diychatroom.com/f5/self-leveling-concrete-questions-114686/)
Dave K 08-20-2011 10:35 AM
I need to float self leveling concrete into a 14'X12' room approximately 1/2" to 3/4" thick. How can I mix this amount of SLC? Can I just mix it in buckets and put it down in several layers?
There are a few small high spots in the floor. What is the best way to knock down the high spots in concrete?
Dave
oh'mike 08-20-2011 10:46 AM
Obviously read the package instructions---
Sand can be added to the mix for high build ups---Material must be added in layers--to much at once and it will crack--
Most require a primer coat before the SLC goes down to insure a good bond.
Some suggest a liquid latex be mixed into the first coat.
A jack hammer could be used to knock off the high spots--also an angle grinder with a diamond cup works well .
My go-to SLC is Jifset and Linewebbers liquid---However that is only because I know its quirks --
There are many good brands.
oh'mike 08-20-2011 10:57 AM
Bud--your 2 cents is needed.:laughing:
Floor Doc 08-21-2011 05:49 AM
ARDEX Engineered Cements
