Self Leveling Concrete In Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 09-01-2013, 10:59 PM   #1
Rewards Points: 1,442
Self leveling concrete in basement
I have a corner that dips about 3/4 of an inch. Didn't notice it until I got the drywall up. Would self leveling concrete be the best bet? Does priming really matter if I'm putting engineered hardwood over it with some type of soft underlayment between the two? I know primer helps it to stick and not dry out too fast, but I figure if it cracks it shouldn't really matter since it's just acting like a big shim for the floor. I could be way off so any advice would be greatly appreciated.
mikegp is offline   Reply With Quote
Old 09-02-2013, 05:01 AM   #2
DIY staff
Rewards Points: 7,174
Primer is essential---without priming the self leveling compound can pop off the concrete--
Old 09-02-2013, 09:37 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Priming takes 10 minutes and a little dry time. Why would you even consider skipping this step?
Darkling Designs
poppameth is offline   Reply With Quote
Old 09-02-2013, 03:58 PM   #4
There's not alot of ventilation down there so of it isn't necessary I would rather skip it. Plus saving money is always good. Am I wrong for thinking it doesn't matter if it pops off since it will have nowhere to go? I'd fill the area with sand if it was considered ok.
Old 09-02-2013, 06:22 PM   #5
DIY staff
If you don't want to prime .use Jifset mixed with Linewebers liquid latex---
This is premium priced---so that won't work ---
Why are you bent on doing this in a cut corner fashion? Loose crunchy broken up compound under your new flooring is acceptable to you?
Old 09-02-2013, 08:21 PM   #6
Retired & Not Likin' It
Jim McClain's Avatar
Originally Posted by mikegp View Post
...saving money is always good.
No it's not. Who taught you that nonsense? Doesn't matter, they were wrong. Sometimes saving money now is costing you twice as much later - and later comes far too soon when you cheap out on something that takes the beating a floor does. You need to understand the difference between marketing BS and good common sense.
Jim
Jim McClain is offline   Reply With Quote
Old 09-03-2013, 07:55 AM   #7
I'm not trying to cut corners if it's going to be an issue. I'm posting here to find out if it's necessary. So I guess I'll prime it. Any suggestions on what I should use as far as concrete? I guess HD would be the easiest place to purchase it. I'm going to check their site in a bit. Thanks.
Old 09-03-2013, 07:58 AM   #8
This looks like it should do the job:
http://www.homedepot.com/p/Custom-Bu...2#.UiXOm38Z9Uw
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Building a SubFloor on a concrete basement dberladyn Flooring 14 01-08-2012 03:00 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Ceramic floor tile on concrete basement floor w/toilet pedestal amp2oo1 Flooring 1 10-05-2009 08:31 AM
