Self-leveling Compound Or Redo Seams? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 09:50 PM   #1
self-leveling compound or redo seams?
First, let me thank you for all the helpful posts in this forum. I'm basically doing this job by myself and have never tackled tile before.
Okay, so here goes - I'm putting down tile in my bathroom. I put thinset down on the wood subfloor and have installed 1/2" hardie backer board. I put thinset on the seams and put down seam tape. I think I put thinset on too thickly because now there's a ridge; I think it's about 1/8" from being flat (level). Question - Is it better to redo the seams by sanding them back down and reapplying thinset mortar to them, or should I apply a self-leveling compound to the whole floor? (And if I do that, do I need to build a dam around the perimeter and somehow cover the toilet drain?) After the floor is fully prepared I will be laying metro hex tiles (the kind that come on the 12" mesh sheets).
Thanks in advance for your help. I want to do this the right way.
cbwakko is offline   Reply With Quote
Old 02-24-2012, 10:18 PM   #2
Rewards Points: 13,458
Well, it should have been 1/4" instead of 1/2 tile board, but no harm done.
As you applyed the thin set it would have been better to have been more carefull and had it flater, but still no real harm done.
Take a putty knife and scrape what you can then wearing a dust mask get it fairly flat.
cbwakko (02-25-2012)
Old 02-25-2012, 10:15 AM   #3
Thanks! That is what I had hoped someone might say. I've been looking at SLC videos and they were pretty daunting. I've used a putty knife and a sanding block and gotten the seams pretty flat. Now I'm going to lay out all my tiles and see how it looks.
Old 02-25-2012, 01:38 PM   #4
firehawkmph's Avatar
Rewards Points: 1,868
CB,
In future projects, Don't tape the seams until you are laying the tile. Go ahead and put down your nylon tape and as you are tiling you will cover the seams with thinset. This way no hump if formed.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Encapsulate Asbestos w Floor Leveling Compound boobleom1 Flooring 5 02-02-2012 09:26 PM
starting floor project with clean slate by using leveling compound robismyname Flooring 1 10-07-2011 12:53 PM
tips for working with self leveling compound and recommended tools for the job wee1945 Windows and Doors 3 07-03-2011 06:54 AM
self leveling compound mmhendrie Flooring 2 09-01-2010 07:39 PM
floor leveling compound geraldS Flooring 4 03-01-2009 08:20 AM
