Self Leveling Compound Advice - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 10:55 PM   #1
Self leveling compound advice
About ten weeks ago I put in a floating solid bamboo floor. Looks great, but I failed to prep the subfloor to the strict tolerances required by the manufacturer. I thought I could live with a few soft spots, but they aren't getting any easier to live with. I think at this point I'm going to tear up some of the floor and attempt a self leveling compound.
My questions are:
1. If I'm not quite up to this due to time constraints, what do you think a decent price from a contractor would ballpark at? Just doing a few spots of compound, I'd do the tear out, re-install of the floor.
2. Are these products you can typically do in just a few places in a room, over plywood subfloor?
3. How messy does this stuff get?
Thanks for any and all advice.
Mr. Michael is offline   Reply With Quote
Old 01-08-2013, 11:05 PM   #2
Rewards Points: 12,844
If you have the time to remove the flooring and reinstall it you can surely also do the leveler and not have to pay someone.
http://www.bing.com/videos/search?q=...wood&FORM=VDRE
You could have just used 30 lb roofing felt to fill the low spots.
Old 01-09-2013, 09:42 AM   #3
I actually have ripped it out once in some areas and tried using paper as a filler for this technique, but it seems to just create bumps instead. I'll try this instead. I assume the technique is the same, maybe just take more time to try it again, not let my wife rush me this time. I've also heard roof shingles are good for this purpose?
Thanks.
Old 01-09-2013, 10:17 PM   #4
Oh, forgot to mention, part of my problem is over sheet vinyl. Will the compound set on vinyl? Or are shingles/felt the way to go?
self leveling compound help/advice needed clubjuggler Tiling, ceramics, marble 3 01-27-2010 09:31 PM
Advice Needed on Leveling Shop Floor shapeshifter Flooring 0 11-24-2009 10:31 PM
Self Leveling compound on hard wood floors?? Tbizzy2 General DIY Discussions 3 05-22-2008 12:11 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
