Self Leveler And Flooring In Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 08-07-2013, 04:35 PM   #1
fire angel's Avatar
Self leveler and flooring in basement
I am finishing a bathroom in our basement. The concrete floor is not level and I have to raise the one side about 3/8 in. I was going to use a self leveler, however the side that it is low has an expansion joint cut right through the middle of the area that I have to raise. All of the self levelers that I have seen say not to go over expansion joints. I am going to lay Dura-Ceramic for flooring. What should I do about the expansion joint. The floor is a small area only about 35 sq ft.
fire angel is offline   Reply With Quote
Old 08-14-2013, 03:34 PM   #2
Rewards Points: 18
Caulk or patch the expansion joint within the area you intend to level, then use the self leveling compound.
bdunk is offline   Reply With Quote
Basement floor Mills314 Flooring 1 11-28-2011 07:27 AM
Another Knucklehead Considers Laying Tile Over Vinyl Flooring tacklingherlist Flooring 14 08-27-2011 12:13 AM
Epoxy over floor leveler? aqhoward Flooring 0 07-04-2010 08:14 PM
Install flooring in a travel trailer...leveler? luan? Zstream Flooring 2 12-11-2009 09:15 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
