Old 10-13-2012, 11:57 AM   #1
They're all fixer-uppers
J187's Avatar
Seeking quick answer please! Self-leveling compound.
If I were to use self-leveling compound to level a concrete subfloor in a hall, my concern is that this room flows immediately into my family room with a high pile carpet. What is the best way to build a dam to keep the compound from the carpet? I'm getting ready to do this hopefully in the next 30 min.
You can see the area here:
J187 is offline   Reply With Quote
Old 10-13-2012, 12:18 PM   #2
funfool's Avatar
After reading your last post, I do not see why you would use floor leveller.
The minor difference you mentioned would disappear with thinset.
Then you have a potential of creating a worse situation then the 1/16" you have now, not to mention what the wife will do to you if you get it on the carpet.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
ToolSeeker (10-13-2012)
Old 10-13-2012, 12:52 PM   #3
J187's Avatar
Thanks. I'm just paranoid that I will have problems once I start and at that point it will be a mess.
Old 10-13-2012, 04:42 PM   #4
Super Moderator
Tape down a strip of wood---or use plumbers putty---
Self leveling compound bcarwell Flooring 4 09-07-2012 01:27 PM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 10 12-17-2009 04:34 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Self Leveling compound on hard wood floors?? Tbizzy2 General Discussion 3 05-22-2008 12:11 PM
Need a quick answer...canned light wease Electrical 5 12-11-2006 10:54 AM
