-   -   Seeking Professional Advice (http://www.diychatroom.com/f5/seeking-professional-advice-67112/)
seagrtj 03-18-2010 03:16 PM
Ok, so I have a 20' X 12' kitchen with a 3.5' X 11' hallway jaunting off of the kitchen that is tiled with ceramic tile. I want to pull all of that up and put down a wood laminate floor.
This the middle floor of a 3 story town home. I can see when I remove the floor vent cover that there is a 5/8" board, 1/4" board, 1/4" board, ceramic tile layered in that order.
So my question is would it be better/easier to remove the tile and the top layer of subflooring to get all of the thinset?
What would be the correct way of doing it all?
Thanks for all your help and patience.
Mark Harvey 03-18-2010 05:08 PM
I'm not a pro, but have done some work similar to what you are askiong about. The total of the 5/8. 1/4, 1/4, bring ther thickness to 1" plus ... which is recommended for ceramic, slate, etc. In your case, if you are installing laminate, I assume it will be a "floating" floor. The primary concern is not the strength but to make sure it is as level as possible. Uneven subflooring will lead to the joints of the laminate not closing properly and it will look like the "planks" has split. Hope this helps.
seagrtj 03-18-2010 06:29 PM
Thanks Mark. Thickness was not my concern. My true concern is getting the thinset off of the subfloor. I don't know how hard this is going to be and was wondering if it is easier/better to just pull up that top layer of subfloor and put down a new one then install the floating floor.
oh'mike 03-18-2010 08:48 PM
Your best bet is to remove the 1/4 inch underlayment along with the tile-- that's the standard practice.
Usually you must beat the tile off the underlayment before you can remove the 1/4 inch.
---Mike---
Mark Harvey 03-20-2010 06:20 PM
I agree with Mike. This is probably the easiest way and will give you a better chance at getting the floor you want.
