Securing Plank Subfloor To Joists? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 01:00 PM   #16
Seems to be general consensus that the 1-1/4" screws I have will do the job.
Mostly asking about the #10 2" screws: Will the ones I've purchased (see above post) work well?
duffman56 is offline   Reply With Quote
Old 03-14-2012, 01:01 PM   #17
Pro
JetSwet's Avatar
Rewards Points: 502
I was taught 1 1/4 screws are never used for any flooring except luon and hanging sheet rock and butting cabinets together.
Be on the safe side and go higher up on the size.
JetSwet is offline   Reply With Quote
Old 03-14-2012, 01:07 PM   #18
Pro
JetSwet's Avatar
Rewards Points: 502
Just because you have 1/2 ply doesn't mean that you exceeded your screw size, I'm just saying that you have to take in consideration that you need to make shore that ply doesnt go anywhere
The more the screw holds on to the underneath the less Likely it's will move. Use your 2" that you have for a piece of mind.
Old 03-14-2012, 01:43 PM   #19
JetSwet
Actually I'm asking if the #10 2" screws are a good size for attaching the t&g to the joists (two per t&g plank, each place it sits on joist).
Old 03-14-2012, 02:20 PM   #20
Pro
JetSwet's Avatar
Rewards Points: 502
JetSwet
Yes they are good sorry about that.
Old 03-14-2012, 02:42 PM   #21
Very good.
These screws claim no pre-drilling is required. If I were to purchase some more (and I'm going to need A LOT more) #10 2" screws that don't advertise this, I'm guessing I would need to drill a pilot hole for each screw to avoid splitting the wood. What size bit is recommended for this?
Old 03-14-2012, 02:52 PM   #22
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Aren't you putting the screw in the center of the boards?
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 03-14-2012, 03:08 PM   #23
Pro
JetSwet's Avatar
Rewards Points: 502
The only spax I have used are masonry type, try to screw it in the board and if you inbed the screw like a 16th inside the board you should be good with out having to predrill.
Old 03-14-2012, 04:28 PM   #24
mnp13:
No, I am putting TWO screws, per plank, per joist. I realize this will be a lot of screws, but I'm told this will minimize cupping.
I was planning on putting a screw about 3/4" in from each edge of each plank. Given this distance would this minimize the chance of #10 screws splitting the planks?
Just wanting to make sure I'm doin the little things right. I am very grateful to everyone for being so patient with such a newb.
Old 03-14-2012, 05:54 PM   #25
mnp13's Avatar
Rewards Points: 512
Well I'm not at your house with you to see the boards, but i would guess at that distance pre-drilling wouldn't be necessary
Michelle
Old 03-14-2012, 07:18 PM   #26
Rewards Points: 252
I didn't pre drill, except at the butt joist because they had a tendancy to split.
shazapple is offline   Reply With Quote
Old 03-14-2012, 09:22 PM   #27
Just put the first screw in (3/4" in from edge) and yep, it split the plank. Guess I'll have to drill pilot holes to avoid this?
Old 03-14-2012, 09:30 PM   #28
Rewards Points: 528
Get a nail gun and shoot ring shanked 8d nails into the subfloor. Screws are not necessary.
framer52 is offline   Reply With Quote
Old 03-14-2012, 09:48 PM   #29
Tileguy
JazMan's Avatar
Rewards Points: 288
Duff,
Just in case you're not in the mood to spending several hundred on a nail gun and a compressor, you can easily hammer 8D deck nails and be done. It's common for the planks to split near the ends. So just drill does, 1/8" should be good.
Jaz
The Following 2 Users Say Thank You to JazMan For This Useful Post:
framer52 (03-15-2012), JetSwet (03-15-2012)
Old 03-14-2012, 10:42 PM   #30
Ok, so ringshank 8d nails will do just as well as the screws? I may switch to them, although the pilot holes/screws went pretty quick tonight.
However, we ran into another problem... After we secured all the planks to the joists I had my wife jump up and down. She is not a big girl... There was noticeable deflection. I went down to the basement to investigate. She was actually only a foot or two away from a steel I-beam which runs perpendicular to the joists. This I-beam has a piece of wood (2x4 maybe) running across the top. The particular joist that was below her is not quite making full contact with the wood on top of the I-beam.
Do I need to put some kind of shims between the wood on top of the I-beam and the bottom of the joists so they are making good contact? Any suggestions on how to do this? I was thinking about trying to pry the joist up so that I could get the shims in. Do you guys think this would work?
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 06:28 PM
Straps for securing gas line to joists - question. DangerMouse HVAC 4 07-05-2010 09:20 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
Securing ceiling joists to a beam t_mccann Building & Construction 9 11-28-2007 03:35 PM
