Securing OSB Sub-floor To Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 06-27-2009, 01:04 PM   #1
Securing OSB sub-floor to concrete
I'm planning on putting down 1/2" OSB sub-floor directly on my concrete basement floor. My question is how to secure it? I have been told to simply use masonry nails with a baby-sledge, but have read a lot about using tapcon screws...
Can I use the masonry nails and be secure or should I go another route?
Rhat is offline   Reply With Quote
Old 06-27-2009, 01:31 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Never gonna happen!
Why on earth would you want to do that to begin with? You are getting some really bad advice from someone.
What do you have in mind after you install the OSB?
Old 06-27-2009, 01:38 PM   #3
Cement allows water vapor to pass thru
I'd never put OSB or any other wood directly on a basement floor that is below grade
Old 06-27-2009, 03:25 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
The OSB will just fall apart in a few months. What are you planning on intalling over it?
Old 06-28-2009, 07:51 AM   #5
Thanks for the replies.
I've painted Drylock (2 coats) on the concrete floor, and was told to put a 6 mil poly vapor barrier down and then the OSB. on top of the OSB i planned to put Bamboo planks due to their resistance to moisture, but I need something to secure them to and was told to put down OSB....other thoughts?
Old 06-28-2009, 09:10 AM   #6
There's not a lot of choices for putting hardood below grade. Any solid product is going to give you trouble due to moisture. Only got 2 choices below grade. An engineered floating product. Click lock with a moisture barrier below. Or, a glue down engineered floor. The second choice is going to start with applying an elastomeric coating as a moisture barrier, followed by a flooring adhesive like Bostics Best. The second method is not for the faint of heart. It's a PIA. If you choose the second option, the best advice I can offer is to not spread anymore glue than you can work in a 30 minute period & lay the planks opposite what is considered normal. In other words, work the tonge into the grove rather than the groove into the tongue, otherwise, you're going to plow the grooves full of glue as you pull the planks together.
pinwheel45 is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Securing Outdoor Concrete Bench Stavros Building & Construction 4 05-16-2009 09:49 AM
Securing subfloor over a concrete pad ktulu05 Flooring 4 06-18-2008 08:19 AM
Securing wall to concrete floor Sandervanoaker Building & Construction 10 05-06-2005 02:11 AM
