Secure Subfloor/fix Hole - Flooring - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 07:37 PM   #1
Secure subfloor/fix hole
Hey all-
So shown below is a picture of the current state of my floor after stripping the carpet and some weird old vinyl tile. I'm am going to be putting carpet over it, but first I want to sure up any squeaks and fix the hole shown. The hole is pretty small but looking through it extends all the way to the plaster ceiling below. I'm assuming there is a subfloor below that is also chipped away since the planks are staggered that means there must be a difference layer below- is this correct? This house is about 70 years old- what would be a typical subfloor type for a home this age?
In order to secure the squeaky boards can I just screw them through to the subfloor? Can I do this anywhere or just at the joists? If just at the joists what is the preferred method of locating the joists? I don't see any nails and the top wooden floor is tounge and groove. How can I go about repairing the hole? It causes a major squeak and the chipped top floor board to depress a little bit when walked over.
Thanks so much
Greg
Secure subfloor/fix hole-pc270144-1.jpg
c00rdb is offline   Reply With Quote
Old 12-29-2009, 08:19 PM   #2
I bet there will be at least 12 people who scream about how good that wood would look if you had it re-finished.
My home is 60 years old and there is no subfloor. A previous, much older, home we lived in had some kind of diagonal planks as a subfloor.
If you're 10000% sure you're never going to want to expose the wood, then to stop squeeks just drive screws through the floor into the subfloor or the joists, as appropriate.
pyper is offline   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
