Old 10-12-2012, 02:28 AM   #1
Second opinion wanted on mastic removal job
Hi DIYers,
I'm looking for a second opinion on a asbestos removal job I had done in our new house. We had VAT over black mastic (containing asbestos) on top of concrete slab on grade from the 50s. We decided to get it removed to do a glue down engineered hardwood floor.
The contract we have says the abatement company will "Remove and dispose of vinyl floor tile and mastic using 3 dimensional scraping." However, it seems that there is a few mm think layer of mastic left on most of the concrete.
The contractor insists that their scraper can't get up any more and said that if we want more removed we need to pay extra for permits and a "mechanical" removal of some sort. However, a simple putty knife gets up a significant amount of the remaining mastic, so I don't understand the issue with their scraper.
Is this standard or do I have a legitimate gripe here?
More pictures: https://picasaweb.google.com/1051803...sbestosRemoval
djmarcin is offline   Reply With Quote
Old 10-12-2012, 09:01 AM   #2
A far more important issue is that sure looks like someone layed OSB directly over that slab. A big no no.
Old 10-12-2012, 09:42 AM   #3
JetSwet's Avatar
Joe is right & that being said taking the osb up will eliminate this issue. This sounds like the osb was used as a hight filler.
JetSwet is offline   Reply With Quote
Old 10-12-2012, 02:40 PM   #4
Hi guys,
Thanks for the feedback. Is OSB = oriented strand board? I'll check and report back but I'm pretty sure the mastic is directly on the concrete and the tan areas are exposed concrete.
If not, any special procedures for pulling up OSB or just start pulling? Or do I have what OSB means wrong?
Thanks,
David
Old 10-12-2012, 05:32 PM   #5
The good news is that a wallpaper scraper or a stand up floor scraper should scrape the cutback (black VAT mastic) right up.
The bad news is it is time consuming.
The VAT is where all (most) of the asbestos was.
What is 3 dimensional scraping?
Rex
atvrex is offline   Reply With Quote
Old 10-12-2012, 05:47 PM   #6
Your correct on what OSB stands for.
I've never once seen tan concrete unless it was stained.
The safest, simplest way to redo this floor is with engineered flooring installed as a floating floor.
I'm just not a big fan of most glued down wood flooring, twice as much when it's below grade.
Far to may people posting with humped up and cupped floors when there glued to a slab.
JetSwet (10-12-2012)
Old 10-14-2012, 07:09 PM   #7
I went back and checked -- there really doesn't seem to be anything on top of the concrete unless it is paper thin. Maybe it was stained, or maybe it's residue from the mastic?
You can tell because of where the carpet tack strip was removed.
I'm not really sure what "3 dimensional scraping" is supposed to mean. I think it just means razor scraping.
The top of the slab is actually a few inches above the ground, and all the documents we have refer to it as "slab-on-grade". It also isn't level -- it was built with a grade in the slab from the center to the sides of the house along one axis, about 1/4" per foot. In addition, due to settling it deflects slightly more near the sides of the house. Leveling it out completely isn't really an option because it would raise the floor too much at the walls, but the built-in grade doesn't bother me.
We initially thought about the floating floor but the flooring company we talked to said that in the long run a glue down would be better. They mentioned that a floating floor will stress the T&G system too much and slowly work itself apart over time.
Any thoughts? Reconsider the floating floor? Thanks in advance.
Old 10-17-2012, 04:47 PM   #8
Why not remove the OSB and glue the engineered floor directly to the concrete using Mapei Ultrabond ECO 995?
Jim Decker is offline   Reply With Quote
Sealing over mastic on basement floor. EddieD Flooring 5 01-12-2012 12:42 AM
asbestos mastic josec Flooring 4 01-04-2012 12:03 PM
Wanted: Second opinion on radiant floor/boiler hookup drh HVAC 4 01-16-2010 09:41 PM
Opinion wanted, does this need to be re done? dtmbizzle Flooring 9 02-21-2009 10:19 PM
Where to run the line...opinion wanted Scottz Electrical 4 10-22-2007 06:41 PM
