Second Floor Noise - Styrofoam? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 01:08 PM   #1
Rewards Points: 248
second floor noise - styrofoam?
Bought a house. When you're trying to sleep on the first floor and people walk on the second floor it is very noisy. The carpets are old and need to be replaced anyway. I'm kicking around the idea of buying 2" sheets of styrofoam and installing the flooring on top of them. Is this a good idea or is it a boneheaded move that I will regret?
jackwashere is offline   Reply With Quote
Old 10-15-2012, 01:20 PM   #2
Rewards Points: 13,694
No idea how in the world you came up with that idea, Bad Bad now go stand in the corner. LOL
A better carpet pad would be a big help, still not enough, you could add another layer of sheetrock to the ceiling below. Far better to just use a thicker carpet pad.
Part of the warmth in a second floor room is from the rising heat from the room below. Use foam and that's not going to happen.
There would be no way to install carpet strips over foam.
Old 10-15-2012, 02:56 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Just to add a little to what Joe said, pull the carpet and screw the sub-floor better to the floor joists too.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 10-15-2012, 03:08 PM   #4
Newbie Bill
Rewards Points: 522
When you say noisy, is it squeaks you are hearing or do you hear the footsteps?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 10-15-2012, 03:29 PM   #5
Rewards Points: 248
Noisy as in it sounds like an elephant or a tank. Loud thumps. Not so much squeaks.
What kind of adhesive to use on Styrofoam insulation? tripower Building & Construction 17 08-13-2013 06:21 PM
styrofoam or fiberglass mjsparky363 General DIY Discussions 0 01-31-2011 06:42 AM
Red Styrofoam pad with stryro foam balls underlayment genner Flooring 4 03-31-2009 10:25 PM
Stucco over Styrofoam skharrison211 General DIY Discussions 1 09-13-2007 05:35 PM
Styrofoam vs. Plastic vent channels dpreznik Roofing/Siding 14 05-10-2007 02:58 PM
