Second Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 04:27 PM   #1
second floor
My second floor is made up of tongue and groove 2/6 wood boards. Some of the floor boards are eaten up by termites. Some of the boards are underneath the walls that support the roof. Is it possible to replace the boards without damaging the house? Also i have no sheetrock on the walls and the floors are bare. there is no carpet or laminate or anything on the floor. We are curently under construction. Should i replace all of the floor boards or just the ones that need it? My house is approximately 2000 sq. ft. 20 percent of the boards are bad and not all are next to each other. The house was built in the 1980's.
Carrasco is offline   Reply With Quote
Old 05-28-2012, 05:36 PM   #2
DIY staff
Rewards Points: 7,174
I would suggest replacing only the bad boards--then add a fresh layer of bc exposure one over the 1x6s--1/2" or thicker---
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
