Seaming Foam-Backed Carpeting - Flooring - DIY Chatroom Home Improvement Forum
Old 12-15-2006, 12:53 AM   #1
The Flying Toolbox
handypilot's Avatar
Question
Does anyone have any suggestions for seaming foam backed carpet? I didn't think one could use traditional seam tape because the glue can't attach/imbed in the weave, and it might cause a bulge.
I was thinking of just carpet tape type seam tape and seam sealer.
handypilot is offline   Reply With Quote
Old 12-19-2006, 10:38 PM   #2
Floorwizard's Avatar
there is a sticky non heat carpet tape.
good luck
Floorwizard is offline   Reply With Quote
why use paint brushes instead of foam brushes? joeyboy Painting 18 09-23-2007 06:52 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Rigid foam as floor insulation rkhpapa Building & Construction 3 09-24-2006 07:06 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing/Siding 3 07-25-2005 06:31 PM
