Seam Separation Problems With Vinyl Plank Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 01:35 PM   #1
Seam Separation Problems with Vinyl Plank Flooring
If your vinyl plank flooring has been installed at least five years, has anyone experienced problems with separating seams? If so, is that problem easily resolved?
island lady is offline   Reply With Quote
Old 03-30-2012, 05:47 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Is this a glue down installation or a floating installation? If it's floating it sound like failure of the joint, either the locking system or at that age, more likely a the glue strip it it attached with. If it's a glue down install it's probably something moving in the substrate. If it were the material itself I would expect it to happen sooner than 5 years.
Darkling Designs
poppameth is offline   Reply With Quote
Old 03-30-2012, 10:24 AM   #3
Rewards Points: 13,472
Is it opening near a wall? If you there was no gap or not enough gap left between the flooring and the wall.
Tags
vinyl flooring Barry J Flooring 1 10-28-2011 05:35 PM
ivc vinyl plank flooring gbgilman Flooring 1 10-23-2011 09:33 AM
No glue vinyl flooring in a wide room? BizeeB Flooring 1 11-23-2010 08:50 AM
Should I Caulk perimeter gap in floating vinyl plank bathroom installation chuck_250 Flooring 2 11-22-2010 07:35 PM
Can I cover old cracked vinyl flooring with lauan and new vinyl? MikeC. Flooring 4 03-12-2007 05:20 AM
