-   -   Seam Separation Problems with Vinyl Plank Flooring (http://www.diychatroom.com/f5/seam-separation-problems-vinyl-plank-flooring-138648/)
island lady 03-29-2012 01:35 PM
If your vinyl plank flooring has been installed at least five years, has anyone experienced problems with separating seams? If so, is that problem easily resolved?
poppameth 03-30-2012 05:47 AM
Is this a glue down installation or a floating installation? If it's floating it sound like failure of the joint, either the locking system or at that age, more likely a the glue strip it it attached with. If it's a glue down install it's probably something moving in the substrate. If it were the material itself I would expect it to happen sooner than 5 years.
joecaption 03-30-2012 10:24 AM
Is it opening near a wall? If you there was no gap or not enough gap left between the flooring and the wall.
