Seam Gap Flexitec Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-26-2013, 06:53 PM   #1
Seam gap flexitec flooring
Oops...my husband did such an excellent job of installing flexitec flooring right up until he cut the seam. He overcut and left a gap, small, on a 12" length. What's the best way to repair this error. He's thinking of cutting another strip and having two seams or possibly trying to find the piece he cut out and filling in and then using silicone to seam it all.
I just felt bad that this happened and the rest of the floor, not an easy configuration looks beautiful!
paulak is offline   Reply With Quote
Old 01-27-2013, 10:55 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Find a piece that matches the pattern and lay it over top of the bad cut. Double cut (cut through both layers) the piece to fit. Pull the old piece out and put the new fill piece in. It should line up perfectly if he cuts it correctly. Then you use a white latex carpet seam sealer to seal the edges of the material together. Do NOT use silicone.
Darkling Designs
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
paulak (01-27-2013)
Old 01-27-2013, 03:53 PM   #3
flexitec seam gap
Why not use silicone sealer? Paula
Old 01-28-2013, 05:53 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Because it isn't the proper thing to seal it with. White latex seam sealer is what you are suppose to seal these types of floor with. Silicone will leave a shiny streak anyway.
Darkling Designs
paulak (01-28-2013)
Old 01-31-2013, 07:30 AM   #5
Resolved
All done...seam fix worked like a charm. Floor looks great. thanks for your help!
Seam Separation Problems with Vinyl Plank Flooring island lady Flooring 2 03-30-2012 10:24 AM
Anyone familiar with Flexitec flooring? codeman10x Flooring 62 04-20-2011 01:58 AM
Flooring with Flexitec littlewomen Flooring 1 10-26-2010 12:19 PM
Flexitec flooring - need opinions taylort Flooring 6 02-25-2010 05:28 PM
Flexitec Flooring need advice lageeslayd Flooring 3 02-25-2010 05:16 PM
