Sealing A Wood Garage Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 05:53 PM   #1
Sealing a Wood Garage Floor
I have an unusual garage floor. It is made of 2x6 planks, like a deck with no space between boards. There is a crawlspace underneath. The problem is that water from a wet or snowy car falls through the floorboards, creating moisture issues in the crawlspace. I need to either seal or cover the floor to make it waterproof, and I'm looking for suggestions. It's in good shape, despite being 30 years old, but it's dirty and oil-stained.
The only solution I have been able to think of would be to cover it with a subflooring material and then epoxy-coat that. Any better ideas much appreciated!
RockyRoads is offline   Reply With Quote
Old 01-11-2011, 06:24 PM   #2
Rewards Points: 272
My suggestion would be to cover the entire floor with tongue and groove plywood, prior to that I would create a grade to it so any liquid would be directed to a floor drain that could be installed. If it is only for moisture from a vehicle I might be tempted to drain into a 5 gallon plastic bucket and allow it to evaporate on its own, this would depend largely on where you live and just how much moisture you would be bringing into the garage. Once all of that was done I would cover it with an epoxy garage floor paint. Just a quick thought.
fixrite is offline   Reply With Quote
Old 01-11-2011, 06:35 PM   #3
Rewards Points: 81
You can cover the entire floor with vinyl that comes in rolls. Here's an example. Better Life Technologies is the manufacturer.
http://www.mygaragestore.com/detail.aspx?ID=1211
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 01-11-2011, 06:38 PM   #4
Excellent thoughts, thanks!
I do live in a dry climate, so the 5-gal bucket would probably work. Or, it would be pretty easy to run a drain pipe to the outside, which I think is permissible where I live. What material would you use to create a grade under the plywood? Just shims?
Thanks again!
Old 01-11-2011, 06:43 PM   #5
Rewards Points: 272
you can buy shims that are composite and not wood, that would be my choice.
cheers
Old 01-11-2011, 06:46 PM   #6
Rewards Points: 272
If you wanted to you could also determine the grade neccessary and cut long shims out of 2x4's. It depends on just how much of a slope you are going to put in your garage. Doors and benches and anything else in the garage might have contributing factors.
The Following User Says Thank You to fixrite For This Useful Post:
RockyRoads (01-12-2011)
How to raise a garage floor to match house floor jlgenz Building & Construction 4 09-05-2010 08:38 AM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 06:29 PM
problem: Water on wood floor during refinishing HouseMgr Flooring 2 08-15-2009 09:19 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Laying "new" wood floor next to sloping old floor troyce1 Flooring 25 10-16-2008 01:34 PM
