Sealing Vinyl Floor Tiles? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-30-2009, 02:31 PM   #1
Sealing Vinyl floor Tiles?
Okay you're all gonna laugh at me, but I've been remodelling a camper for the past couple weeks. Its been a fix as I go knid of project and I've been trying to keep things inexpensive. I've been trying to find a new counter top for it and so far haven't found too much under 50.00. Not that 50.00 is expensive, but I don't want to replace the whole thing its still sturdy I just want to cover the ugly finish thats in there now. And 50.00 for a piece of arborite? So we had some extra vinyl peel and stick tiles that we've used. Believe it or not, they look pretty good. My queston is, is ther some kind of sealant that I could use along the seams? I would want to do the same had it been used on the floor, but I've never used stick-on floor tiles before.
Platinum is offline   Reply With Quote
Old 10-30-2009, 03:58 PM   #2
R&D Tile is offline   Reply With Quote
Old 10-30-2009, 04:45 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
heh heh, heh heh
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 10-31-2009, 09:55 AM   #4
Originally Posted by R&D Tile View Post
JK Floors is offline   Reply With Quote
Old 10-31-2009, 10:19 AM   #5
Home Slave
Lazy_Jake's Avatar
I've been installing TrafficMaster tiles in my bathroom and where ever there was a slightly visible gap between pieces, I just take some caulking with my finger and rub it into the seam. Keep rubbing it in to fill the and hide the seams and continue rubbing until all the excess caulking starts to roll up and just wipe the little caulking pills away. My tiles are beige and I used white caulking. You can't even see where I filled in the gaps, but they would be slightly visible if left alone.
Lazy_Jake is offline   Reply With Quote
Old 11-01-2009, 06:32 PM   #6
Rewards Points: 182
No offense, but that is a waste of time.
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
