-   -   sealing slate (http://www.diychatroom.com/f5/sealing-slate-1837/)
shaun 02-09-2006 08:43 PM
sealing slate
I am installing a light colored slate in a kitchen. I would like to darken the slate to give it a "wet" look. Seakers and enhansers do nothing. I tried a satin varathane on a sample and it is exactly what I want. The slate is pourous and not smooth so there should be no problems with this finish sticking. Are there any problems doing this???
R&D Tile 02-11-2006 07:57 PM
I only use sealers made for this, check with the manudacturer of this product and see what they say.:)
What sealers have you tried already, Aquamix and Stonetech both make sealers that will give you that look.:)
http://www.aquamix.com/for_home_use/products/
You will probably have to strip whatever sealer you used , before applying another, 2 coats of whatver you use should be applyed before grouting, grouting slate is a PITA.:)
Did you seal this floor yet or try the sealers you didn't like on a sample?:)
shaun 02-14-2006 08:25 AM
sealing slate
Thanks for the reply R&D. I tried the sealers on samples only. I will try the aquamix products.:)
