Sealing Perimeter In Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 11-21-2014, 09:39 AM   #1
Rewards Points: 56
Sealing perimeter in basement
I installed click together (not glue) vinyl planks in my basement. They are 100% waterproof, but if I ever have a flood, I'll have to pull them up to dry the water underneath. Is there any way to seal the perimeter so the water can't go under the floating floor and it will just stay on top?
diyGK is offline   Reply With Quote
Old 11-27-2014, 12:46 AM   #2
Rewards Points: 6
You would have to use a 100% acrylic silicone???This will allow for expansion and contraction...However, if you get an excessive amount of water on top of the floor...chances are, well very good chance...the water will penetrate the seams.
So in my opinion....don't bother.
Renoagain is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
air sealing basement Fix'n it HVAC 9 04-06-2012 09:58 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
Interior perimeter drain for basement water joshm General DIY Discussions 9 05-30-2009 10:08 AM
Sealing basement marly General DIY Discussions 1 11-21-2008 04:09 PM
