Old 04-24-2008, 07:41 AM   #1
mcu
Sealing/painting cement slab for humidity?
Hi,
I am redoingmy sub floor in the basement with 2x2 dricore tiles and was wondering if there would be any advantage or disadvantage to painting/sealing the cement slab before installing the 2x2 tiles. Would it cut the humidity even more?
There are some cracks in the cement do I have to fill those before laying the subfloor down?
Also is there any benefit to gluing the dricore tiles together since they are already tongue and groove?
mcu is offline   Reply With Quote
Old 04-24-2008, 09:25 PM   #2
mcu
anyone? don't be shy!
Old 04-24-2008, 10:53 PM   #3
Tileguy
JazMan's Avatar
I think it would be a waste of time. First, floors should never be painted, if anything slabs can be stained. Paint will wear off and can peel in some circumstances. Paint will do nothing to reduce humidity. If you have high humidity your Dricore underlayment would work either. Did you read the Dricore info well?
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Cement slab timing sluggermike Building & Construction 5 11-09-2007 05:53 AM
Radiant Heating on Cement Slab can'tdecide Flooring 2 08-21-2007 01:59 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
