Old 06-09-2009, 04:21 PM   #1
Sealing newly installed pre-finished bamboo flooring
We recently installed pre-finished bamboo flooring in our house. I have become extremely paranoid, not about scratching the flooring, but about liquids getting between the floor boards and wreaking havoc. We have pets that I'm sure will make a piddle in the house at some point and I'm certain something will get spilled sometime soon.
Is it possible to apply some kind of sealant on top of the newly installed flooring that will not only help protect the surface of the floor boards but also seal up the cracks between each board to protect the bare wood between and under the boards from spills and such? If so, is this a good idea and can anyone recommend a good product for this job?
Thanks!
brandon272 is offline   Reply With Quote
Old 06-10-2009, 06:45 AM   #2
Doer of Many Things
poppameth's Avatar
You'd have to put anther coat of urethane on it. Most manufacturers will probably recommend you have a floor sander screen it and apply a coat or two of Bona Traffic water based urethane.
poppameth is offline   Reply With Quote
Old 06-10-2009, 11:25 PM   #3
Tileguy
JazMan's Avatar
Sounds like you've just realized you shouldn't have chosen wood as your floors? There is no way to do what you've suggested and have it last more than 6 months or so.
First of all it would be silly to apply a sealer on a new floor, and lots of work too. Because wood shrinks and expands all the time, any new finish will crack as soon as the wood shrinks.
You're right to worry about spilled water and pets. I suggest you place their water dish away from your new floor. Even small pets will drool water as they walk away from the dish. You might see problems within a few years? If the pet is a dog, well, good luck if it's medium or large in size. You may know, (?) bamboo is softer than most other wood used for floors.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
bamboo flooring: wide or narrow boards? blakekr Flooring 4 11-09-2007 04:29 PM
Laying 5/8" Bamboo Flooring kirkeric Flooring 7 08-13-2007 03:36 PM
Laminate Flooring - Is It Installed Under Bathroom Cabinets? BDPNA Plumbing 92 02-07-2007 01:02 PM
Sealing southern pine flooring DMA Flooring 1 02-28-2006 10:37 AM
