Old 05-12-2006, 12:01 AM   #1
Question
Sealing Concrete Garage Floor
I just bought a new home, and I would like to seal the garage floor. Its concrete. Does anyone have any suggestion about what to use? I was thinking epoxy but I didn't know if it was likely to pill off with use? Thanks for any suggestions!
rlrife is offline   Reply With Quote
Old 05-13-2006, 12:51 PM   #2
Darylh's Avatar
I would just put a good clear concrete floor sealer but if you decide to put some colour on it get some runners and place them where the tires on your vehicle will be. Hot tires peel off any paint in no time.
Darylh is offline   Reply With Quote
Old 05-13-2006, 10:14 PM   #3
I used a 50/50 mixture of kerosene and tung oil. Cleaned new concrete with TSP and rinsed, rolled on the mixture and buffed with a scotch brite pad. About a week later redid it. Warning though trying to use a buffer on a slick floor can be dangerous. You cannot manhandle the buffer. Also if you put it on don't plan on being able to etch it later and put paint on it.
oldgoat is offline   Reply With Quote
Old 05-14-2006, 11:30 AM   #4
Contractor
Another trick is to stain it prior to sealing. I have done a few shop floors with stain approved by the DOT for marking concrete. I used 'handicapped blue'. Even steel wheeled engine stands with over 500#s of marine engine on them didn't harm it.
Teetorbilt is offline   Reply With Quote
Old 05-15-2006, 02:50 PM   #5
Thank you all so much!
Old 07-18-2006, 05:48 PM   #6
Hey,
Again, the best source I've found for info on concrete sealers is www.mightyseal.com. Check out their "educational link" it has a lot of info about different kinds of sealers - as I said earlier, they even mention the kerosene trick on there. Even though they are a retail site, they still have some great info.
www.concretenetwork.org also provides some excellent help.
Hope that helps,
Pilot
Pilot is offline   Reply With Quote
More On This Topic
You can do countless projects by simply using concrete mixed with varied additives. You will go about the project in different ways depending on exactly what you need to pour. Buy and add the appropriate additives per the instructions with your concrete... Read More »
Concrete floors are long lasting, well supported and fairly simple to maintain. With stamps, patterns, stains and polishes, they are popping up in places beyond the garage and basement. Cleaning your concrete floors should be part of a regular home... Read More »
We've mixed up some more concrete and we're just in the process of finishing off this job here. Put some back in the bucket, here. Once this dries, in a day or so, we can come in and lay our tile and that will finish up our floor. The reason that I'm... Read More »
Concrete floors are long-lasting and fairly simple to maintain. With stamps, patterns, stains and polishes, they're popping up in places beyond the garage and basement. Cleaning and caring for your concrete floors should be part of regular home... Read More »
Many people take great care of their vehicles, but don't keep up the maintenance on their horse trailers. Cleaning a horse trailer not only keeps it looking good but can help the trailer last for years. Follow these steps to learn how to clean a horse... Read More »
Raising Garage Floor to match House Floor felice_oggi Building & Construction 2 09-22-2006 08:26 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 05:13 AM
sealing garage floor rl10851 General Discussion 4 04-03-2006 01:13 PM
Garage Floor leveling. Marsharo Remodeling 1 12-30-2005 03:11 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
