-   -   Sealing/Cleaning Mold & Water Damage on subfllor (http://www.diychatroom.com/f5/sealing-cleaning-mold-water-damage-subfllor-117402/)
michaeloro 09-16-2011 12:12 PM
I am in the process of putting down a new laminate floor in my living room.
I started pulling up the old laminate which was put down before I moved in, it is glued down, no vapor barrier. By the front door there is a little spot maybe a total of 2 or 3 sq feet. The board is solid, appears just to be superficial. I think it was due to the front door not having any weather lining before I moved in, which I took care of a couple years ago.
I don't think the subfloor needs replacing. I intend to try and clean the mold and water, then put down underlayment and new laminate.
I searched a lot and see everyone saying to clean the area which bleach and then use kilz to seal it, although there is some disagreement on brand, etc...
My question is can someone tell me the exact product to buy, Kilz has a # of different types of there products, oil vs water based, etc... Or if anyone has some other suggestions I would love to hear them, as long ts the product is widely available like at home depot or lowes.
Thanks for the help.
JazMan 09-16-2011 03:32 PM
Hi Michael,
I've got a better idea, one that actually works. Bleach is almost useless to kill mold on porous materials. I recommend you use Concrobium instead. http://www.concrobium.com/
You should not need to apply any primer/sealers on the spots afterwords.
The orange place carries Concrobium as well as many neighborhood hardware stores.
Jaz
Floor Doc 09-16-2011 04:39 PM
I use a product called Microban .
Microban Disinfectant Spray - Mildewcide, Bactericide, Fungicide, Deodorizer, Anti-Microbial
Jaz is right , Bleach will kill it , but won't prevent it from coming back .
michaeloro 09-16-2011 05:24 PM
Thanks to both of you, I appreciate the advice
Floor Doc 09-16-2011 07:22 PM
Welcome
