Old 08-12-2008, 07:59 PM   #16
Seal Peel and Stick Tiles?
Is that sealer a lot of maintenance ?
Do you need to reseal every time you use the magic eraser ?
Or every time you clean ?
Does the sealer look bad if you use the magic eraser and don't recoat ?
NoExperience is offline   Reply With Quote
Old 03-16-2012, 03:39 PM   #17
Ok. I read the directions. No help.
I have trafficmaster ceramica peel & stick tiles, installed groutless. These are NOT vinyl comp. tiles -- the colour layer is about 12 thou thick. The body of the tile is murky gray green.
The tiles have rounded edges, so there is a groove perfect for funneling spilled coffee, runoff of soaked dogs and kids, snowy boots into the subfloor.
While the tiles are pretty tight, I don't kid myself that they are water proof. Will the VC surface sealer work to water proof the cracks, or do I need some form of seam sealer?
sgbotsford is offline   Reply With Quote
Old 06-22-2012, 12:50 PM   #18
Unhappy
Nestor_Kelebay, I found your article of Jun 8 on sealing vinyl floors extremely helpful. I have a vinyl peal and stick floor I did not seal the seams on (expensive product and being ignornant of the consequences left that step off). I have cats with lots of hair. The flooring has developed a gooey ooze on the seams which is hard to remove (I have used Goof Off) but it eventually comes back. This was laid over sheet vinyl. I want to seal the seams and the whole tile/floor. Will the "Technique" or "First Down" products you recommend seal the seams too? Or do I need to bite the bullet and seal the seams only or seal seams first and then whole floor? Between the sticky goo attracting long cat hair and everything else I am about to pull my own hair out. I can't afford a new floor but I want something to make life easier until I can. I hope you can help!
sewmama is offline   Reply With Quote
Old 06-22-2012, 02:39 PM   #19
Pro Flooring Installer
rusty baker's Avatar
Nestor hasn't been here since 2009.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 06-22-2012, 03:33 PM   #20
Thank you Rusty for that info. Maybe you can help me then? Any ideas? Anyone?? Maybe if I seal the seams now the problem with be solved but don't know if I need to if I seal the floor. High traffic area and sick of the sticky floor. Just don't know whether to seal seams, then floor or just seal floor and hope it takes care of the seams. THanks!!! ANy help is greatly appreciated!
Old 06-22-2012, 09:56 PM   #21
Ugh..... I wouldn't rent any apt with vct on the floor If i wanna see some vct ill go to walmart. Now that is what some laminate is supposed to look like!!
Last edited by oh'mike; 06-22-2012 at 10:08 PM. Reason: Removed link--read posting rules
Floor installer is offline   Reply With Quote
Old 06-22-2012, 10:07 PM   #22
JetSwet's Avatar
I second that notion, I'm with you on vct lol
Last edited by Gary in WA; 06-23-2012 at 12:20 AM. Reason: Removed ad link in quote.
JetSwet is offline   Reply With Quote
Tags
floor care, kitchen floor, peal and stick tile
Peel and Stick Vinyl tiles nunie305 Flooring 3 03-06-2012 03:04 AM
Peel and Stick Vinyl Tiles tscan Flooring 4 11-14-2011 08:10 PM
Peel & Stick Vinyl Tiles rachel23 Flooring 13 10-16-2011 08:14 PM
Do I fill the cracks when I am putting peel and stick tiles? bherdman Flooring 5 04-05-2010 05:01 PM
Peel & Stick Tiles onto Plywood Subfloor kimmyb Flooring 5 01-25-2009 04:07 PM
