Seal Granite Before Grout? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 01:33 PM   #1
Seal granite before grout?
I am sure this has been covered in past posts,I can not seem to find it.The title says my question.Do you seal Granite before you grout?
Thank you in advance.
mark942 is offline   Reply With Quote
Old 03-07-2008, 04:09 PM   #2
I have heard it can be done either way...before or after. Just make sure if you do seal before you grout to not get any sealer inbetween tiles, the grout may not adhere to the fullest extent!
baksdak is offline   Reply With Quote
Old 03-08-2008, 07:34 AM   #3
Thank you baksdak..................
Old 03-08-2008, 10:04 AM   #4
Tile Contractor
Bill_Vincent's Avatar
Hang on a second!! Some granites don't need to be sealed AT ALL! The only granites I'd worry about sealing before grouting would be flame honed. If you're working with polished stone, I wouldn't worry about it. It'll clean up fine.
As for how to determine whether your particular stone needs to be sealed or not, you can take a sopping wet sponge and place it on the granite. After a couple of minutes, remove the sponge and wipe off the excess water. If there's a dark spot on the granite, it should be sealed (after it dries, of course!). if not, you're wasting your time and money.
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Old 03-08-2008, 10:52 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HERE WE GO AGAIN!
I already told them that Bill but several posts have been deleted due to a misunderstanding and editing of posts. Even the beneficial comments have been deleted.
Old 03-09-2008, 08:21 AM   #6
DepotDweller's Avatar
Originally Posted by Bud Cline View Post
HERE WE GO AGAIN!
OMG, I guess I'm naive........didn't think people did that. What's up with that? Oh well.......weird.
DepotDweller is offline   Reply With Quote
How to seal a real granite counter top ?- Moved from Granite Transormations. Klavisha General DIY Discussions 1 02-24-2008 08:20 AM
another grout color change question tryinitmyself Flooring 1 02-22-2008 06:50 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
Do Tile setters seal grout? Yeti Flooring 2 10-24-2007 05:18 PM
Decorative Etched Granite Listello csteinke Remodeling 1 06-08-2007 11:54 PM
