Seal Cat Smell On Brick - Flooring - DIY Chatroom Home Improvement Forum
Old 08-08-2007, 01:27 PM   #1
Hi, I Bought A House, gutted it, and sealed the entire thing with zinser. This was to seal the song smell of cat urine. This worked with great, outstanding results. The only problem i am experiencing is that i just moved in, and there is still a partial smell in one part of the house. There is a marble brick wall, with a fireplace and two planters (if thats what you call them), which are marble bricks in a boxlike shape. The Cats had apparently left some presents and urine in this area. At the Bottom of the planter, there is a tightly placed peace of wood, and below it is most likely outer house foundation. I need to seal the smell on these bricks, and even after going as far as painting over them with white zinser, there is still a smell. if you know a product that could help me please post.
note: if this is the wrong section please tell me where it is supposed to be
flyingzs is offline   Reply With Quote
Old 08-08-2007, 01:29 PM   #2
Anyone?
Old 08-08-2007, 01:37 PM   #3
Guest
Guest
Posts: n/a
You need to use a shellac based product such as Zinsser BIN. What Zinsser are you using?
Old 08-08-2007, 01:59 PM   #4
that will work on brick?
Old 08-09-2007, 05:56 AM   #5
Guest
Guest
Posts: n/a
Should work on virtually anything. BIN sticks to glass if you really need it to.
Old 08-09-2007, 01:20 PM   #6
Rewards Points: 150
One thing to try is to treat the area with an enzyme cleaner smell remover first... we have cats and dogs, and use Nature's Miracle quite a bit... It does work quite well....
slakker is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 12:11 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 10:06 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
